please add my id to the whitelist
Please add my ID to the list, I am having this same issue with my current firmware version. My ID: 1837839409
Seems that the problem hides in HA. It is a bug
Please add my ID to the whitelist, I am also having the issue with my current firmware version.
My ID: 6229015080
Please add me to the BETA
ID 1588676280
Hello I wish the beta too
ID 166360957
Thank you
Kindly add me to the beta list as I have the same issues.
ID: 6356670781, Server: Europe & Africa
- Mainland China Server
- My ID: 6355142498
Hello! I have the same trouble
ID 4182420009
@liufei
Facing same issues - please add me too:
ID 1637842657
+1 facing issues with connectivity, ID: 6359663147
I have exactly the same issue with 12 Color Bulb IIs now constantly going to “unavailable” in the Yeelight app and the MI Home app.
I have tried multiple servers, three different routers.
This is not related to Home Assistant.
Please whitelist my MI account, which is 1901258438.
I am also having issues getting the bulb to show up correctly in home assistant
Please whitelist me: 6229592150
Please add me to beta. Cannot connect anymore from HA
Userid: 1582345523
I have same problem with lamps ylxd50yl:
I have two lamps yeelight ylxd50yl, after upgrading the firmware to 2.0.6.0025 the devices don’t work properly.
The control is lost some time after switching on — the lamp is not found in mi home app and yeelight.
The control is lost with bluetooth dimmer and remote control as well as with aqara wall wireless switch.
The lamps work fine on homekit protocol.
The other yeelight Meteorite lamp continues working normally from both apps and remotes.
The network configuration is based on the mikrotik router. The lamps are located not far from the router.
The ping response time of the devices is within normal range 3-50ms, the same is with yeelight Meteorite lamp.
The Yeelight Meteorite lamp has 2.0.6.0049 firmware.
Can you add me to the whitelist as well, MI ID: 1742326755
Facing issues with connectivity, MI ID: 136795227
Have the same problems.
I have two smart LED Bulbs 1s and after the framework update they do not connect with the app. They are shown as offline. I tried resetting them but when I try to add them again on the app I get a message saying connection failed. I have not change any settings on my router and I have entered the correct WiFi password. My internet connection is stable and I use the Europe and Africa (Frankfurt) server. The lights were working fine for months until I upgraded to the last framework. I’m not even using home assistant, just the yeelight app.
Please downgrade me. MiID: 6339418521
No its not, i had a lot of yeelights - my Bulbs und Stripes work flawlessy without any Issues! But the ceiling lamps going offline from time to time!
