Hi, so much issues with connectivity on firmware 2.0.6_0030, can you whitelist my id: 517936411, europe&africa server(francfort), tell me if I have to switch to proceed to the firmware update.
thks
thks
I have the same problem.
Bside lamp 2 a nd bulb!!!
Please add me to beta. Cannot connect anymore from HA
Userid: 563634746.
Help!
Hi can you please whitelist me too
Miid- 6372465029
Hi, can you please add me too:
Miid: 6372389428
Server: Germany
Having disconnect issues with Yeelight S1 color, firmware 2.0.6_0030
I can still telnet and ping the device, but Yeelight app says it is offline, so does HA.
I tried using one of the accounts with pw:yeelink1234, but no firmware update available sadly.
This is my first experience with Yeelight, and besides the perfect capabillities, this is disappointing me.
I have continue problem with beside ii and yeelight white…
connect few minuts or hours.
After disconnect.
Hello, I have the same problem on two Yeelight 1s on 2.06_0030, can you whitelist me? Thank you very much!
Miid: 1898839373
Server: Germany
I’d like to be included
need to get two bulbs back to 2.0.6_0024
6375137416
US
Also having issues with my bulbs, socket closing and messes my home automation. I can only send commands but the bulbs doesn’t answer back which causes errors.
My bulbs are using 2.0.6_0030 and no updates showing.
Could I be added ?
6290332152
I made the mistake of updating my Firmware on my 2 bulbs, standard and color version, a couple of weeks ago. Now they keep going offline and all my searching online led me here.
Please whitelist…
Mainland China
MI ID: 1855058457
These devices are now basically useless
Please add me to whitelist, bulb goes offline
Mi ID: 6169679833
What does it mean to be Whitelisted , do I get the latest firmware before others every time or only now?
I have the same issue as others with Yeelight Color v2 , I also have Yeelight Color 1s and this one works perfectly .
My yeelight app isnt linking to my google home…anyone have a solution for that?
Please add me to the whitelist. ID: 174312166
Thank you in advance.
my id : 563634747
THANKS!!!
I have several problems with my yeelight’s light I can’t integrate them to the home kit anymore
Whitelist me pls.
ID1334894448
China mainland server
Would you please white list me.
MI ID: 66241915
Server: Chinese
ceiling24 2.0.6_0005
ceiling17 2.0.6_0008
Fixtures are constantly lost for 30 seconds. Day and night.
Bulb closed the connection.
This is a huge inconvenience, often the light does not turn on when needed.
Logger: homeassistant.components.yeelight
Source: components/yeelight/ init .py:485
Integration: Yeelight (documentation, issues)
First occurred: 17 октября 2020 г., 15:46:17 (217 occurrences)
Last logged: 8:52:49
I am also experiencing issues with my Yeelight 1S. Could you please add me to the whitelist?
After I updated the firmware to 2.0.6_0030 I am experiencing that the bulb is closing the connection on my Home Assistant. Changing the DNS to 8.8.8.8 in my router does not fix the problem
My ID: 6317188532
I can connect and add the bulb in the Yeelight app and turn it on and off.
Home Assistant keeps saying “Unavailable”
The bulb worked perfectly on stock firmware with both the Yeelight app and Home Assistant.
This is the error is gives.
“Unable to update device 192.168.1.111, yeelight_XXX: Bulb closed the connection.”
Please also add me I can’t connect any yee light since this week.
Please add me i have 2 yeelight 1s an 4 bside lamp 2 and 4 strip led…
Work few time in home assistant. Cli close connection.
id 563634746
Many thanks
I updated to v2.0.6_0025. Seems I have the same problem((
The firmware is broken LAN in Home Assistant. After the update my lamps stopped working with Home assistant.
Add me to test new firmware.
Mi ID: 1583409085 (Chinese server)
