No. It does not cycle. It is a white bulb so I believe it should blink. But it does not do that - It is also definitely a wifi version.
Oh, a white bulb, I was thinking it’s a color one. Could you do another test? Setup a hotspot, name it “miio_default” and the password to “0x82562647” and see if the bulb will connect to it? If yes, that means the bulb is under factory mode, we can send you a tool to change it to customer mode.
Hi, yes I did connect, and then disconnected.
Hi, I got the same error with a RGBW bulb. Can I use the same hotspot name to try to recover it?
If RGB bulb is in factory mode, you will see red/green/blue blink in turn when power on.
It is exactly what is happening.
Pls try with the following link to download the application to fix. (Android platform app)
Quit_factory_appplication
Note:
The app will enable a hotspot named with “miio_default”, if it failed, pls setup manually.
Hotspot configuration:
SSID: miio_default
Password: 0x82562647
Security: WPA2_PSK
Just a little update. This sorted mine right out! Thanks for your help! Appreciated!
I can not seem to get this to work. I have two and one connected right away the other well i tried the reset and it will not flash. I tried the default wifi thing and still i cant find the bulb on wifi. i tried calling the customer support number and i guess because of my provider im not allowed. Please help
Are you creating a personal hotspot on your phone?
I tried to on my iPhone but couldn’t make it.
Sorry, I did it on a android with the above app that the above staff posted and it worked first time. - See if you can borrow a android phone from somewhere. I know it’s annoying I was in the same boat as you. Got one working but the second refused until I used the app. Good luck.
Hi,
I have one which refuses to be reset.
I have done the reset but it on white, after blink red/green/blue in turn and then white again and blink red/green/blue and white again and it continues
on a loop.
Even I setup a hotspot, named it “miio_default” and the password to “0x82562647” but the bulb not connect.
Could you help me please???..
Thanks in advance.
What voltage do you use, does it match with the bulb?
Hi I am having a similar problem but with a colour bulb…i am unable to get it working…Requesting your help
Which device do you have? Could you describe the issue more detail,. Thanks.
Hi… I have the first generation Yeelight RGB colour bulb (YLDP02YL). It was working before but now i am unable to reset the bulb and it is not being added to the app as well.
On switching on and off it blinks red light for a fraction of second and does nothing after that.
Requesting you to let me know how can i fix this and get it to work
Regards
How about post a video to show the issue? Seems a hardware issue, but I’m not sure.
And could you see a hotspots with name like “yeelink-light-color***” in your wifi settings?
Hello, I have the same problem. Before the bulb worked well, now I can not connect it, I stopped using it for a while because I did not have a phone. By wanting to reconnect it I can not make it work, it just flashes white. I uploaded a video to YouTube trying to show the problem.https: //youtu.be/EfXvcLyeBvQ I downloaded the Fix application and it did not work either. I opened the hotspot manually and it seems that it does not detect it. Any suggestions?
