Hi, after read the thread:
seems that my ceiling has the same problem and stays on factory configuration. The light turn on by itself and change also the bright as it want.
i create a wifi hotspot with values:
Hotspot configuration:
SSID: miio_default
Password: 0x82562647
Security: WPA2_PSK
and yeelight connect to it, but i’m not able to download the application using the thread link (seems not available):
Could you give some solution?
Thanks, best regards.
