Please try another version of my program to see if it solves anything now. https://drive.google.com/open?id=1RLK_77zSKWHjvcDe6V7vyPfw-UEU6sw9
@matheod I don’t have so much hope on you because the official demo doesnt work on your computer, but you can give it a try to see if anything changes
Still doesn’t work but thanks anyway.
Maybe Jordi could try to allow us to add ip of light to see if it work without having to go through the discovery phase ?
En mi caso funciona bien la aplicación de Pablo donde me detecta 6 bombillas aunque solo tengo dos, pero sigue sin funcionar el toolbox. Saludos.
That is just for testing purposes. My app only sends through the wifi or ethernet adapters
So it should work via Ethernet too and not only with Wifi?
Anyways my App is not detecting anything…
I was connected via Ethernet then I tried Wifi but it’s the same…
(I have downloaded SlimDX x64 too)
Edit : Wait I’ve found an important information to tell to users !
You MUST activate the “Local control” for EACH devices in the mobile application !
I just found out that 2min after writing this message, I had an illumination lol
Hope it can help some peoples
Yes, you need to enable LAN Control on each device. Then the app will detect them even through ethernet.
You definitely should add that in the first post, I think that it can help some people that have troubles
Sure, you are not the only one realizing that, I will update the post as soon as I release the new app version
Hi,
I have tried the app on two different setups (PC, Win10, Ethernet & PC VM, Win7, WiFi) with the same results. App works fine, I can see, turn on/off, change colour on my bulb and lightstrip.
When I enable movie mode though the app freezes and is unresponsive. I have to kill it via task manager. Of course movie mode (which is what I mostly want) does not work.
Can someone please help?
Thank you very much.
By the way Jordi.id96, is it planned to add the group function ?
Hi,
Read the first post.
Did you installed :
.NET Framework 4.5 or later.
SlimDX End User Runtime (required only for movie mode) https://slimdx.org/download.php
Hi!
I already have .net framework 4.7.2 in my main setup. The link you provided is broken. I have installed SlimDX 4 for x64.
I am aware of the issue and I think I found the cause. I’ll release soon the next app version containing the fix. Thanks for the feedback!
Of course, sadly I can’t say when, I’m too busy so it won’t come soon…
We are patiently waiting for your new version that will hopefully solve the movie mode crash issue.
Thanks a lot!
Version 1.2.0 published. Includes fixes, some features requested by users and a lot of under the hood improvements.
As always, feedback is much appreciated!
Nice work man ! I will try it, looks good so far
Next step, adding group function
For me, still the same - DOES NOTHING.
Movie mode crash is fixed!!! Just tested it and it works great. Latency set to 400 ms. Only problem with s is hen screen is dark. Overall looks fine though.
Thanks a lot for your work.
