Yeelight IFTTT service is now officially published
米家和Yeelight都切换到新加坡服务器,然后把设备快联到新加坡就可以了。
用homekit的话需要打开极客模式,因为走的是本地局域网,和服务器就没有关系了。
我中国人啊,英语平常用的多一些 :)
谢谢解答。
我的yeelight app已经切到新加坡了,但是米家没有找到在哪里进行切换。
另外还有一个问题比较重要,请问我的斐讯k2路由器,yeelight 吸顶灯,如何使用homekit控制?
米家需要退出登陆,然后重新登陆,登陆的时候可以选择服务器,一个登陆框下面的小地方,要注意一下。
要使用homekit,需要自己搭一个树莓派,具体的话可以看论坛里面关于homebrigde的帖子。
感谢回答。
所以说除了搭建树莓派,我没法自己把homekit刷进路由器了吗?就像小米路由之前支持homekit插件一样
还有米家切成新加坡地区的话,我在北京操作,会有什么不好的影响吗?比如摄像头传视频缓慢
建议您还是用树莓派吧,路由器刷的话不一定能成功。
北京操作新加坡服务器肯定会慢一些,你可以先用一个两个设备看看能否接受。
200多元的树莓……好吧 我先研究研究如何操作 多谢啦
I was wondering if you will support the action of Blinking? To show notifcations? Also Im getting an Even though I have scense in the app?
IFTTT is not launching scenes for me at all. 1 light toggle seems to work.
Scene work fine from Yeelight app.
Same problem here, I use IFTTT to trigger my Scene when I say a phase to Google Home, days ago, everything works fine but since yesterday, it stopped working. When I said a phase to Google Home, I get the respond message but the scenes were not activated at all.
@stunned @djinnmoto It’s some bugs occurred on us,and we fix it now. I’m sorry for that,can you try your scene again?
Yes, it’s working again now! Thanks for your quick solving the problem.
I’m glad to help you with the problem and thanks to choose Yeelight.
hey guys, I’ve an issue with the IFTTT widgets. do you have problems to?
I’ve tried everything but nothing helped. it doesn’t react at all.
what can I do?
Will there be an option to blink the lights xx number of times via ifttt??
Thank you
There’s a scene named with “Flash notify", you can try with it.
Or you can create your own blink light in Customization.
Yesterday I got 2 * LED Bulb (Color) that are connected to Yeelight app. The app is connected to Singapore server and integrated in IFTTT (it shows “Status active” on their website under My Applets>Yeelight).
I try to create a new applet in it always returns me Options Unavailable, I’ve tried different apples - Set Scene, Toggle lights on/off, but it always states Options Unavailable
Do you have any advice how to make it work?
Maybe reconnect XIAOMI oauth can help you because of expired of the accsstoken.
how to do that?
Please follow those steps.
