How to remove notification widget???
Since the other frames have timers what’s the purpose of the Pause Frame on Customization?
Suppose you want to stay on last frame for a while before running next frame
But it’s exactly the same thing if i just add that timer duration on that last frame, isn’t it?? What’s the difference? I guess it will be interesting only if pause frame also turn light off during that period…
When you add a timer for a frame, it’s called a transition timer. Suppose your frame N is stopped at color A and you add a frame N+1 with a duration X and color B, then the logic is: change the color gradually from A to B in time X, the total step the transition costs = (X / 20ms), here 20ms is the transition granularity.
We dived the changes to very small step in order to make all the color changing smooth enough.
Ok, now i get it! Sorry but i tested with short duration timers and didn’t understand it’s a transition timer… By the way, there’s any chance to implement no light frames? One more question… can i make use of this customization on Tasker? When i try to edit a task it shows only my Yeelight favorites…
Yes as when it’s running it drains my battery like crazy
Will add it in next release!
New user here. Having issues with wake up timer. Set it in the new beta but light does not turn on at the set time often. Is the wake up timer a function of the light or is the phone turning on the light at the time requested?
Using the bedside light plus Nexus 6 running 7.1.1 with the newest beta from play store.
Any help troubleshooting would be great.
