Connection timeout issue
Hello! I followed the “connection timeout fix”. I used the lixin@yeelink.net account and successfully added my device (LED colour bulb) to that account. I also updated it to the latest firmware using the China server. However, when I tried to use my account to add the device, it doesn’t work. Help please. My account is 6226216577
Hello My account is 6227166971
Which device do you use?
Xiami Yeeligth bulb E27
Please have a check which firmware version do you use?
I have the current version, 1.4.2_0038
I’ve tried adding the bulb to my account and it still wouldn’t work.
It only ever works through the lixin account.
Got no idea, we use long account to test from our lab with version 1.4.2_0038, it works well.
can you please whitelist me ? I’ve added device named LightMichael my account id is 6227693512 - can’t see in the lixin the *56 firmware version yet.
thanks,
Michael
Can you please reset password account I tried to connect but it says wrong pass.
Thanks in advance
Hi I try lixin account, but password incorrect. Please help
Hi, I have the same issue with the " Yeelight Meteorite LED Smart Dinner Pendant Lights". I can see the device and the processes goes as normal until 65% is reached. After that i always get the message of the connection timeout.
My ID is 1884514350 and I’m based in the UK using the recommended Germany server.
Any help on this would be greatly appreciated.
Thanks in advance
I think I’ve solved my problem. This is far from ideal but for the moment it worked so I decided to share it with you.
This is only for the specific problem when the DNS in your router/connection need to be changed but in my case as the router is own by my internet provider I couldn’t do that.
So for that specific problem my solution was.
1.- turn off my WiFi at home
2.- creat a hotspot point with another phone with same name and password than my home
3.- use my phone for the connection. In this case I didn’t have to but change the DNS is easier than with the router.
4.-connect the lamp with the normal process
5.- set everything up.
6.- turn off the hotspot
7.- turn on WiFi
et voilà all set.
I hope this helps others but as I said only for a very specific problem.
Cheers,
Hi there,
i cant connect my Yeelight JIAOYUE 650 to my router. It is in the DHCP list from the router but at 100% it says connection timeout. I tried connecting via mobile hotspot but that doesnt work either. I use Germany as server.
My ID is 6163919629 and i already have one ceiling light connected where I did not have this problem. I tried to change DNS server etc.
The lixin login doesnt work any more password changed?
Can you help me please? How can i connect it? I am using the Yeelight App.
Hey can you reset the lixin password please?
Hi, having same issue with color bulb
My user is 6150779668
Can’t use the lixin user, can you guys fix it ?
Just got the password back, have a try.
thank you man! Solved it!!!
Thank you so much for the solution. I was at my wit’s end with this problem. Finally got it resolved by following your steps.
Could you please whitelist me too? my id is 1889145173
thanks a lot
p.s. user and pw not working
