Hello, I connected with the account you listed, the lamp worked, I updated the firmware to the 56 version.
Then I reset the lamp and logged into my own account, but I still had the connection timeout issue.
What should I do? My ID is 6156508276
update: I did the same thing once again, I got the 58 update (China server) and everything worked out!
OK.
I`m using 114.114.114.114 for mi devices. But when connecting from a mihome plugin, I often get a message that the lamp is not online. After repeated attempt - I successfully connect.
I spent 3 afternoon to connect 2 lamps to the network without luck. I tried everything… I wanted to write on the forum when I saw this forum thread. This was the only thing that worked. I was over the moon when finally my lamps connected. Thank you very much Dingyichen!!
I’ve followed the instructions above. The lamp connected to the above account successfully. The firmware updated to 1.3.0_0055. I’m still unable to connect with my own account. My ID is 6159945777. Do I need to be added to a white list?
