Can you please enable low-brightness patch for my account?
MI ID:4171907967
Thank you very much.
Please add the patch for me.
MI ID :6324669397
I would like to apply to this patch please. My Mi ID is 6341359957
Pls add me to whitelist too.
6446648772
I would aldo like to be added to the list if still possible. My Mi ID is 6173343491
Please Enable lower brightness whitelist to my Id 6410376143
MI ID :6324669397
is this still the official solution? Has anyone who’s asked to be added in to the patch had any action to report?
Same issue here with my Arwen 550S YLXD013-A.
The minimal brightness setting is way too bright.
Also the color accuracy is already bad, yellow is green for example, so nothing to break in this department…
The lamp is on firmware 2.1.7_0011.
They have already many times said they will not be doing anything about this and if you want a fix buy the new bulb… there is a workaround listed above, I gave up and installed led strips in the rooms to use for low level lighting
Please, add patch for my account
MI ID: 1597893732
Hi.
Could you please add me to the whitelist for the patch to lower the brightness?
My Mi ID is 4159682457
Thank you
Please add me to a patch list
MiID is 8288384287
