After the 1.4.2_0069 firmware update some lighter RGB colours lost a lot of brightness from my v1 bulb. For e.g. I have matched an incandescent bulb with rgb(255,160,70) (16752710 for the set_rgb command) because the 2700K colour temperature wasn’t the best match, however the brightness of the incandescent bulb, the RGB and the CT mode were the same (at 90-100% brightness value in the app). After the firmware update in RGB mode the max. brightness faded to about 60% of the original. In CT mode (2700K) the brightness remained the same.
After the disastrous update I have reset the bulb and re-added in the device list but the brightness loss didn’t change, so it’s in the new firmware.
Is there any news? The same happened to both of my bulbs. On white settings they are fine, but on colored they are very dim. It happened after a firmware update (not app update).
