Hello, I’m living in turkey.
if I bought those 2 lightbulbs from alixepress seller and i will get Chinese version from that seller.
These devices can only connect to the Chinese server?
If you buy the Chinese version, you cannot use the device in Turkey. If you want to use the device in other regions, you need to another server version
if I buy a Chinese version of a bulb or anything else, will it be possible to connect it to the Yeelight app set to EU server?
We do not recommend that you do this. If the Chinese version of the bulb is connected to a European server, it may cause a lot of connection problems and affect your normal use.
In addition, new firmware will be launched later, causing overseas servers to not support the Chinese version.
We have EU version bulb , you can buy it.
