Hey there. Purchased another lamp and I can’t add bedside lamp D2 to Mi Home app. I can add it to Yeelight app but the light doesn’t show up in Mihome nor it can be manually added.
Is this again lack of support as with what I have been experiencing with Pendant Crystal lamp or am I doing something wrong?
Are you sure you are on the same servers? You don’t have to add anything to both apps, once you add it to any of Yeelight or Mihome, it will be visible in another.
Hi there. Absolutely 100% positive that this is true. I have lamps and bulbs in Yeelight app which are not showing up in MiHome app but not the other way around. Fx. Crystal pendant lamp SKU: YLDL01DL not approved on the European server. Now this LED Smart Lamp D2 appears to be the same.
I also have 2 Yeelight LED strips who’s colour can’t be set to regular WHITE light in the app but you can set it via a voice command on Amazon Alexa?!? Apparently there is a firmware upgrade that they selectively enable on some customer ID’s but not all ?!? Super disappointed with it. I started building a smart home lightning system on Yeelight in my summerhouse have now 10+ lights and 4 of them have major issues as above.
Way too many for only a handful devices. I could just imagine the level of complications I would have if I had 50+ lights like I have in my main house where I have Hue for the past 7+ years and never had any of these problems and only 1 spot light failing after 5+ years in use.
I bought it on AliExpress. Not sure it would be possible to return it to China and than back to Europe with those sellers. How far is this one in the audit? Will it eventually be added to the supported list?
