I have a bulb that changes to red and flickers when the lights are dimmed a little bit. It happens with warm colors. When I cut the power to the bulb and back on again, it works fine for about 12 hours. Then back to where I started.
This is related to topic below. Yeelight says this a hardware issue that they cannot fix, so they are asking us to request hardware replacement from seller.
Thank you, I did not see this. Unfortunately I probably won’t get a replacement because I bought it dirt cheap from AliExpress. I will certainly try.
No matter how much you paid, the bulbs should work. You can try requesting a refund or a replacement. First contact Yeelight support and mention the issue from them. If they respond saying that you need to replace the hardware, show that as evidence to the reseller.
