Mine’s not working too
ID 1630764127
I did it how you would normally create a scene and selecting “Turn on to a preset scene” and they don’t work with Alexa or Google Assistant. If I activate them inside the Yeelight app they work.
And the only thing that works with scenes activated through Google Assistant or Alexa is turning on and off the bulb or “Turn on and customize light” but only a white setting, color and flow don’t work either.
Scenes don’t work nomore… I hope this is a network error that is going to be fixed soon
Mi ID: 1593720213
hi can you tell me which server did you choose ?
@ALL please record me the mid and which server you choose and your scene name and which platform google home or alexa you use.so i can check the data
Server: Singapore
Scene: Night Light
Mi ID: 6336422807
Server: Europe and Africa (Frankfurt)
Scene: Sunrise bedroom
Mi ID 6276806200
Server europe and agrica (frankfurt)
Scene : all scenes, created or already existing. For example, “morning”.
@ALL i have just add some detail log for debuging the issue,if you have the same situation please try once again and record me the mid and which server you choose and your scene name, thanks
@ALL if you try again and it works right than it solves
Mi ID 6276806200
I’ve tried 3 scenes, nothing works
Scenes : bonjour, apero, coin tele
we have found the problem and it would be solved today ,sorry for this.try it later
Mi Id: 1630764127
Server: Singapore
Scene: Morning, Evening, Night, Relax
Mi ID: 6279014011
Server: North and South America (Oregon)
Scenes: HN, quick wake up, study time, zoom call setup, sunset on, Notification (and every new Scene I create)
Hello, now it’s almost working well. Bulbs activation/desactivation works, intensity of the light is ok BUT the color is blue for some routines ! Note that it’s still working perfectly if the scenario is launched from yeelight app.
I’ve tried to create new routines in google home and new scenarios in yeelight app and it is the same issue. I’ve tried to adjust the “default light” but it’s still the same issue.
Strange thing is that some routines works perfectly (good color)…
For my list, google home routines that lead to the same result as yeelight app :
“Bonjour” (Standard routine in google app)
“Heure du coucher” (Standard routine in google app)
“On va chanter” (Created routine, and the only one with a non-white color defined, it’s purple)
“On va regarder la télé” (Created routine)
All the other ones leads to a blue light.
Thanks for your help.
Now the lights are not working at all in Google Home app and Nest smart display. It shows they are not responding or offline. Scenes do work again now
Same problem here but with Alexa,
Starting from yesterday, scenes from the yeelight app are not working anymore with Alexa, to be more precise, some of them are not, but it all happened without any changes from my side.
Going into details, in the Alexa app, the scenes that are working have under the “Description” field the definition “Scene connected via Yeelight”, while the scenes that are NOT working anymore says “Yeelight smart scene”.
Mi ID: 1686529599
European server
Scenes not working so far: luce notte, luce sera
Multi color scenes (100% brightness 3 seconds, 0% brightness 3 seconds) still not working if activated in Google home: it just set the first color on lights.
