Yeelight Bedside Lamp 2 - LAN Control issue after update fw to 2.0.6_0041
Hi, can you please add me to the whitelist?
my mi id: 1766881907
Thank you so much.
I really need an open LAN
MI ID:1607278129 (China)
Thank you!
Please.
I NEED THIS FEATURE
MY ID: 6338074396 (Mainland china )
需要局域网控制功能,MI ID: 370467382,中国大陆,北京服务器
Hello. Please activate this feature.
My ID: 1626416867 (Server Europe)
Thanks in advance!
Please add me to access LAN Control, very important !!
Mi Account number - 1686659902 China Mainland
Thanks, I’m from Chile and my ID is 6406742403
Waiting over a month for my account to be approved!
Please add my ID to the whitelist! MI ID: 6352820742 It’s so bad that we all need to manually ask for this and then wait for you guys to approve
@chyhaiyuan:
Please whitelist my Desk Lamp, to get back LAN-Control. Current FW: 2.0.4_0066
MI ID: 1853790615 Mainland China
PLEASE
Hello @chyhaiyuan could you please kindly add me to the whitelist to get back the LAN control?
My ID is 6256272921 (Europe).
Thank you in advance, Sir!
Hello!
My ID: 1645707730
I need control LAN
Thank you!!
i got an Update now trough xiaomi app only. after installing it. the lamp is now fully broken, i can use it only over the buttons on the device himself. inside the xiaomi app and yeelight app the lamp is marked as offline constantly. removing power doesnt help.
my home assistant find the lamp on my lan but reports also an error
2021-06-03 10:31:23 ERROR (MainThread) [homeassistant.components.yeelight.config_flow] Failed to get properties from 192.168.0.31: A socket error occurred when sending the command.
Update: I did a factory reset (few times). now i am unable to bring the lamp back to my home network at all. with both apps, xiaomi and yeelight.
Please add me to access LAN Control, very important !!!
I’ve been waiting for a long time and there is still no change in FW
my ID: 1686376663
China server
My actual version is 2.0.6_0041
STOP BEGGING FOR LAN CONTROL!
There will be no more unlocking. Stop wasting your time.
There is a custom firmware that will make it work (just look some topic above).
If you are cool enough to use lan-control features, you are for sure cool enough to modify the device too.
Do not stop requesting this. The more pressure the better.
yeah this may work for european or american companies, but you must be blind if you think this helps here.
And as i said, all of you guys are barking at the wrong person.
Would you complain at your car producer if you got bad gasoline at the gas station?
This is a xiaomi product and yeelight is only the producer. Its nothing that yeelight can decide.
Get it in your brains, find your own solution or at least complain at xiaomi forums… idiots.
BTW: The solution is HERE. In this forum, only some posts above. So what are you still complaining about.
For those who are not very into reading, here is the link again:
can you please explain us how to turn on lan mode again with miio cmd? thanks.
Hi, add me please to to firmware update list. Mi ID 1707929232 Mainland China
My ID is 6243244302 (Europe and Africa (Francfort)).
For those who use Home Assistant I found a solution :tada:
Install HACS - Search for Xiaomi Miio for Yeelight - Install Integration - Restart
Settings - Integrations - Add Integration - Miio for Yelight - Put IP and Token (use the modified vevs app to extract the token)
