Yeelight Bedside Lamp 2 - LAN Control issue after update fw to 2.0.6_0041
I’ve been trying to download the 0.43 since you released it but it’s constantly stuck at 1% and then fails.
It never successfully downloads.
Can you please help?
hi mate
can you please add my id:96057786 to the whitelist?
I need the lan control.
Thank You
Hello!
My ID: 1747601188
I need control LAN
Thank you!!
I dont get the new 43 firmware version.
It says I’m on the latest one.(ID 6271869726)
My ID is 4161115913.
Thank you dude :wink:
Mi ID: 1745486503 thanks!!!
Same here, stay at 1% :cry: :cry:
yeelight is only manufacturer of xiaomi lamps.
yeelight is not designer of xiaomi lamps.
All proudct features is from xiaomi,
so we can not take the lan control back officially.
So, in this case, It would be better to inform your users in time to prevent your users to be unsatisfied. When you inform your customers correctly before a restriction applies, they can choose their best decision: miss the future updates and hold the 3rd party functionality OR keep updated but lose the 3rd party functionality.
This step is unacceptable, totally opposite of your valuable customers.
No problem, there’s still a good way to take this situation back to good.
You should re-release your last LAN control-enabled firmware to all of your devices (I have Mi Desk Lamp 1s, so whitelisting won’t work for me without the supported fw) alongside informing the customers about “LAN control will be deprecated in 30 days”.
Everyone would be happy.
Please try to get your customer’s trust back.
If I’ll lose my LAN control, I won’t buy any Xiaomi/Yeelight device anymore… And I think, I’m not the only one.
You screwed up your customers, they never forget it.
Need lan control
Mainland Singapore
Thanks, @chyhaiyuan , it worked for my lamps.
Thank you
your update work?? impossible to do it, stay always at 1%
Same problem!
I ended up setting up the lamp as a HomeKit integration in Home Assistant.
Could get Yeelight to fix it for ther last 3 weeks.
It s ok now
Reset first after update and reset again
Now all is good it s not write Lan but it works
same +1
I cannot update to 0.43, since it’s stuck, so opted to use a workaround described above.
@chyhaiyuan
Please add my ID to white list. LAN CONTROL is very important for me.
Mi LED Desk Lamp Pro
My ID: 1609246460
I had no problem at all.
In fact, they updated on background. I just started the update and let them go…
@chyhaiyuan 求助,42更新43失败,一直卡1%,重置了很多次床头灯还是无用,手机开热点给床头灯也更新失败
Yes thank you, lan feature is a great deal, my Mi id is 5392856909
