Hey guys. I downloaded an older version of the Yeelight app from apkmirror. Version 3.2.40 to be specific. LAN control does show up there! I’m using this solution till I get whitelisted.
Can you please add my id?
Id; 1776867465. (Singapore)
Please whitelist also mine: ID: 1662213919 Poland/Europe
Installing an old version don’t worked for me.
The option is here on the app but impossible to active it…
The lamp is on v41…
Still no signs from Yeelight…
Hi @chyhaiyuan
I have too the LAN control that have disappeared/did not work since fm upgrade.
MI ID : 1848637263 Mainland China
Thanks a lot, best regards from Brazil!
Problems here with Bedside Lamp 2 and Mi Led Desk Lamp without lan control. Bulbs are ok.
Hello @chyhaiyuan,
Could you please help me also with the LAN Control and last firmware ?
Im stuck in 2.0.6_0030
My ID is : 1873124888 (Frankfurt server)
Thx
Hi @chyhaiyuan .
I need you to whitelist my Id in the firmware.
My Id is 1587151608, Mainland China server.
Hello, I just upgraded the lamps and got the lan control disabled. So I need the special version too. My id is 165870005 China mainland, please enable it for me.
Thank you
Was anyone actually able to make it work, after being whitelisted?
I have the update available for about a week, and it won’t load onto the lamp. It’s stuck on 1% and fails every time.
Tried every possible thing, from cache clearing, uninstalling, a dozen or so resets, etc.
Can you please add my id too? It’s 1658700050 China mainland. I must bring this feature back. Thank you
Bonjour my id 6268180116.
Hi. Please also add me. ID 6186200587
Thx.
Hi, LAN is important for me, MI account number 6295323508 thank You
麻烦在帮忙加一下白名单,小米ID是475727536,谢谢
ID 1583218101
Please add to white list. Mainland China
Hello!
My ID: 1582207510
I have a couple of yeelight bulbs with the same problem. I need control LAN
Thank you!!
there is an issue in version 42, if reset, you need to enable LAN control in app.
but no option for lan control in latest app now.
so in version 43, auto enable lan control after reset.
yeelight is only manufacturer of xiaomi lamps.
yeelight is not designer of xiaomi lamps.
All proudct features is from xiaomi,
so we can not take the lan control back officially.
Hi all
For all of the above IDs, I have added them to wihitelist.
follow the steps to upgrade:
- select china mainland server in app(whitelist is only valid for china mainland server).
- upgrade mijia bedside lamp2 to version 43.
- reset the lamp(lan control will be auto enabled).
please check and download the version 43 in app as soon as possible.
new version (without lan control) is coming, it will replace version 43.
