Mi desk light pro "lan control" after update does not work
@chyhaiyuan
Please add my ID to white list. LAN CONTROL is very important for me.
Mi LED Desk Lamp Pro
My ID: 1609246460
LAN option is VERY IMPORTANT, please help
@chyhaiyuan we so need your help. Please give us firmware with lan control.
Downgrade to a lower version of Yeelight app. Works for me for now
Nope it doesn’t help. The firmware update disable lan control function. So, your advice not help.
Which firmware and which app version do you have because I tried with no success.
Yeelight support,Please add my account1599029766 to white list, I lost Lan control. I need it for integration. Thank you
For the desk lamp used with HA, you can use the HomeKit integration of the HA and use the pairing code to add the lamp back.
Please add my Mi Led Desk lamp 1S to white list.
Mi ID: 16230236179
To connect the Home Kit integration, you need a Pairing Code.
The lamp is pkupalas a few years ago and there is no box with the code. How can it be restored?
Mi ID: 1832489151
Product: mi desk lamp 1s
Firmware Version: 2.1.7_0012
Server: Germany
@chyhaiyuan
Please add my Mi ID: 229481299 (Chinese mainland). This is for Mi Desk Lamp 1s
Please add mine too!
Mi ID:1646046600
Chinese mainland
Please give me access to FW version with Lan Control Enabled.
mID: 1795211461
Server China Mainland
Thank you.
@chyhaiyuan
My ID: 1609246460
@chyhaiyuan
And i need LAN control too.
ID 1680683723
Please add me
Id 1731152032
Europe
I’m waiting from a couple of days…
Is it someone from Yeelight following this thread and enabling the right firmware?
Nothing. I plan flash ESPHome to it on weekend. https://github.com/richardklingler/yeelight
@chyhaiyuan please read also here.
I find solution for work with lamp in HomeAssistant with original firmware.
  1. find HomeKit code (on botom of lamp)
    homekit-pairing-code-example-labels
  2. reset your device and you recive in HA message that new HomeKit Controller found
  3. just enter number from code in format xxx-xx-xxx in connection menu
    in sample it’s 123-45-678
  4. block lamp on firewall and do not upgrade it
Thanks yeelight for creating problems out of the blue.
It’s so interesting to understand why the equipment has had an impact
I was planning to replace a few fixtures and was considering yeelight products. Now it is clear that it should be removed from the list of options
