I find solution for work with lamp in HomeAssistant with original firmware.
find HomeKit code (on botom of lamp)
reset your device and you recive in HA message that new HomeKit Controller found
just enter number from code in format xxx-xx-xxx in connection menu
in sample it’s 123-45-678 -
block lamp on firewall and do not upgrade it
Thanks yeelight for creating problems out of the blue.
It’s so interesting to understand why the equipment has had an impact
I was planning to replace a few fixtures and was considering yeelight products. Now it is clear that it should be removed from the list of options
