Yeelight LED Bulb 1S color issue after a long work
Hi Guys, Same issue here. The problem I have is only with yeelink.light.color4… the 1S.
Yeelink.light.color1 and 2 works. (First and V2)
Whats the problem with 1S… Is there still no fix?
Yeelight, please contact me!
It’s unbelievable that the problem is still not solved! How it’s even possible. Upgrade one of my 4 1S bulbs and it is such a disappointment. Yeelight shame on you! Years for not doing anything with a problem which have all 1S owners.
HELLLO?? 2022 and still having the problem. I would love to get the W3 instead but its incompatible with Apple Homekit idk why. If you do not want to fix this issue, at least make a new/updated version?
Bump in 2024. Issue is still persisting. Any updates?
I recently purchased these lights, and the initial firmware version was 2.1.7_0036. I updated three of them to the latest version (2.1.7_0039), and these three lights started having problems. The lights that didn’t update the firmware had no issues. After reading this discussion thread, I noticed that the problematic firmware versions were different, but the common factor was that they all had updated firmware. Therefore, I believe that the firmware update process itself causes the bulbs’ original firmware to get damaged. I suspect that if I don’t update the firmware and keep the factory firmware, there should be no issues. However, for the bulbs that have already been updated, I can only replace them, which is sad. A big company like Yeelight shouldn’t have this kind of problem. It’s clearly an issue caused by the OTA update. Even until 2024, they are still selling these bulbs without any remedial measures, which makes me very disappointed with Yeelight.
