【NEWS】Yeelight Joins the Razer Chroma Connect Program, Bring Gaming to the Next Level [BONUS INSIDE]
Hello, I have the lightbulb 1S RGB and Razer Chroma can’t control the brightness. #FF0000 looks exactly the same as #010000 :confused:
Hello,The screen bar cannot be updated, the problem doesn’t seem to be an isolated incident.
Have heard from several and read that they cannot update the lamp.
I wrote to support and they said it should go now. Of course it doesn’t work and the update keeps breaking off.
I sent two videos to support.
Once with the Yeelight app and then with the MiHome app.
Everything doesn’t work. Has anyone already managed to persuade the lamp to update?
Same problem here, the strip 1S is not usually detected by the Chroma Connector.
But after a lot of tests, I’ve been able to see it for the first time, I had to unplug the strip and plug it again.
If I reboot the PC the strip is no longer detected so I have to power cyrcle it again.
Very frustrating…
I think the Chroma Connector app is buggy…
@candicewj93 my strip 1s dont show in Yeelight Chroma, can you tell me why? Thank you!
Hey Dear, please kindly make sure you follow the set up instructions here in the connection,
If still not show up, please do the troubleshooting as following,
  • Make sure the LAN control has been enabled.
  • turn off your firewall, in case the signal cannot be received by the app.
  • If you’re using ethernet, please switch to a WI-FI network,
  • If you’re using a wifi network, please restart the wifi network and try to connect again.
Any progress on getting each 1S addressable individually? Using ambient awareness without the ability to assign an area of the screen to each 1S bulb is nowhere near as immersive.
Hi Candice,
I was wondering if you knew more about the possibility of setting the brightness of my 1S lightstrips with the 1.0.12 version of the Chroma Connector app. It seems like Chroma Studio does not respect the brightness setting, and is just on 100% brightness.
Is there a workaround, or some other way to fix this? I have used 1.0.11 but my strips did not show up there.
Hi, you can ask you to add color intensity adjustment to the Chroma Connector or Chroma Studio application where there is a monitor image capture. Because the Yeelight bulb w3 is rather faded if it is not full red, blue or green.
You are so cool
I will probably never buy a Yee product again in my life, the fact that my bedside lamp 2 was working with lan control and after the firmware upgrade not, makes me very wary off this company, the fact that it was sold with lan control then taken away. No sorry Yee
good steps
thanks for support
Are there any plans to support the older RGBW bulbs and bedside lamps? or is it just the new S line products and onwards?
