YLXD50YL (2.0.6_0025) Home Assistant Unavaliability
your MI ID please
done
App. Mi home, Yeelight - do not see update 2.06.0026
try again
Yes, there is an update, thanks. So far only one luminaire has “disposed”, installed update 2.0.6_0026. I entered the Assistant into the Home, the lamp appeared. In the first minute, after a couple of switchings, the lamp became inaccessible again. But after 6 minutes the lamp became available. Further, I turned it on, turned it off many times, until everything is normal. That is, for 1 hour so far there has not been a single failure, the lamp is available both in Mi Home, Yeelight, and in Home Assistant.
This is encouraging!
Soon it means “unpack” the second one. Leave me access to the update for now.
Dear Rex Yan,
The FW is available but it will not update von X.6_0016., will Start until ~ 5-8 % than Jump to 99% and about 3 min it will over me again to install the same version 0026.
Dear chakamad,
First disable lan ctrl mode,second reboot the light. After that try update again.
I’m having exactly the same issues with 1S bulbs (YLDP13YL) and Home Assistant after upgrading to 2.06_0031. Is there a newer version for this model to try?
My MI ID: 6312608971
I updated to v2.0.6_0025. Seems I have the same problem.
The firmware is broken LAN in Home Assistant. After the update my YLXD50YL stopped working with Home assistant.
Add me to test new firmware.
Mi ID: 2476577961 (Chinese server)
everything is super. thanks for dropping the firmware so quickly. add to the release so that all people stop suffering. Thank you
Are you able to send me the update on to the Singapore server or I have to switch my setup on to the China’s server?
Current (latest) firmware 2.0.6_0016.
Mi ID: 6244818626
Can you add me too? 1670804290
Thank you.
Hi @rex_yan1
I have 2 lamp YLXD50YL
can you add me to the whitelist, please?
My ID is: 4166087318
Thank you so much
Hi @rex_yan1
same issue with lamp YLXD50YL firmware 2.0.6_0025
Can you enable 2.0.6_0026 for me as well?
MI ID: 6374585785
Hi can you enable this for me as well? I have YLXD50YL on 0025.
Mi ID: 6359800677
Hi can you enable this for me as well? YLXD50YL
Mi id 1875704593
Hello !
Can you enable this for me as well?
I have to 2 bulbs YLPD13YL
My ID: 1728623232
Thanks a lot !
hi @rex_yan1, please whitelist me for version 0026
Mi ID: 1841018069
Hello, please enable me too, thanks.
Id. 1906784192
@rex_yan1 and @All_milight_team
when the version 2.0.6_0026 will be available to public? I’m having this issue since I bought the lamp YLXD50YL.
Why haven’t you launched yet a fix for it?
even the app doesn’t work well… Come on this is a very expensive light, at least give some attention to the public!!
Whitelist my account if this is the way to go…
MI ID: 1764708527
