HA Discovery broken in new firmwares
I recently updated one of my white bulbs to firmware 2.0.6_0041, and it seems to have the same problems as described in Urgent firmware downgrade request (2.0.6_0051) Home Assistant Unavaliability with HA discovery. I see on that thread that firmware 2.0.6_0065 is available and seems to have resolved this, if I’m reading correctly. Is there an equivalent fix for the white bulbs?
Alternatively, is there any way to downgrade to my previous firmware (1.4.2_0018)? I’m on the Singapore server, User ID 1878641305
It’s HA’s compatibility issue and I believe they are already working on the fix now.
Thanks. I thought that the 2.0.6_65 version had fixed the problems that were seen in 2.0.6_0051 for the color bulbs, but I’m still seeing problems in the white-only bulbs, so I wasn’t sure if it’s fixed. In any case, thanks for your response, and I’ll see what happens there (for example https://github.com/home-assistant/home-assistant/issues/26186#issuecomment-565738264)
