Beta list please !!! My ID 1600146462 !!!
after whitelist me, i updated the firmware to 2.0.6_0054
the problem still exist and having connectivity issues.
2.0.6_0054 did not solve the issue
is there a way to downgrade ?
my id: 1819852929
thank you
After I add Yeelight bulb as a hardware in Domoticz, it starts to generate ping timeouts for a few seconds. After a short period of time the device goes offline. When I disable it in Domoticz, there will be no more ping timeouts. Looks like LAN controlling is defected in this firmware.
ID 1781373949 server United States
Is it possible to whitelist me for a downgrade?
MI ID: 1779114679 (server US)
Hello
Mi ID : 1645640770
Homeassistant user
If possible please downgrade to pre homekit firmware so that i can use my bulbs (12) again.
Or if beta can bring my lights back in homeassistant then please add to beta list
thanks
Also Home Assistant user here. I installed the beta firmware 2.0.6_0054 and I still have the same problem. This firmware did not fix the problem. My lights are still not detected by homeassistant. Looking forward to new firmware.
Hi, please whitelist me for a downgrade. Mi ID: 1685949900. Thanks.
Please whitelist me too for the downgrade, If the beta solves the problem then for the beta
MI ID: 169651806
Please whitelist me for the downgrade.
MI ID: 1808985608
Please whitelist me for downgrade, or beta if downgrade is not possible. The lights are unusable like this.
MI ID: 1627927445
Germany server
whitelist pls, i asked before but are not getting any updates ?
MI ID: 1906418033
MI ID: 1578905808
I’m now with 2.0.6_0054 firmware but it doesn’t look good either. Please allow me to downgrade to previous working verion. I don’t need homekit functionality.
My ID 6178784079
The light is currently caused my mi gateway intermittently down. Anyone has this issue?
URGENT
Please also allow me to downgrade the firmware ASAP. I upgraded my lights to 2.0.6_0051 (not sure what the previous version was) and now all lights at home are no longer available and cannot be controlled via Home Assistant. (everything is controlled via automation). PLEASE HELP.
My ID is 1838080491
THANK YOU.
URGENT
My ID is 1721285015
THANK YOU.
Please whiteliste me too. MI ID 1836792912
tested 2.0.6_0054 in offline mode and still having problems with with bulbs becoming unavailable.
I don’t use homekit and i don’t want my bulbs to be exposed to the internet.
Please make v 1.4.2_0038 available, this firmware is working in HA with the bulbs in Lan-Mode
Hi! Please whitelist me for a downgrade!
Mi ID: 1860199427
