please add me : 1602826680
Chinese Mainland
Chinese Mainland
My problem fixed when I switched from Apple AirPort Extress to old ASUS router. I bought Xiaomi router than - no problem as well
Please add me to the whitelist for new firmware versions (Mi ID: 1623790595)
please add me : 1638762739
Server: Spain
I’m using Hassio (Home assistant)
Is there a similar problem with the 2.0.6_0041 firmware for the white (v2) bulb? I’m not seeing it in HA, it no longer responds to the mDNS (and if defined manually, shows up as Unavailable), but it works in the App. And, of course, it can’t be downgraded through the app…
Please add me to the whitelist for new beta firmware or downgrade please. I have full yeelight setup working very well with home automation tools and now is completely broken.
Mi ID::17099630517
Please add me to the new beta firmware program.
Mi ID: 1589604379 (Mainland China)
Please add me, also having troubles
Mi ID: 1794619447 (Mainland China)
Please add me to whitelist, bulb goes offline
Mi ID: 1667097850
Please add me having troubles with my google home
Mi ID: 6273234638
Hello , Please add me to the beta firmware program too, my id is 1908430196
PLEASE ALSO ADD ME TO THE PRERELEASE OF TEST FIRMWARE.
MY ID IS 1827732001 on the CHINA SERVER.
For me bulbs with HK support are still “unavailable” intermittently in HA with 2.0.6_0065… “Bulb closed the connection”.
Thank you for your efforts and prompt reaction to this issue.
Hello plz downgrade my yeelight v2 it start flicking blinking in green color shade and all other colors are ok . My I’d is 1868199301 plz downgrade all my devices thank you
My bulb start flicking if I change colors manually drage and move around all the colors and it starts flicking in green color area . I have the same firmware you have
Same problem here. I’ve got 2.0.6_0065 and I want to downgrade
mi id: 1612640480
I see that the problem continues and do not inform, I want to downgrade the version without previous errors
Mi ID: 1763341038
Server: China
please add me id 1839154583 (united states)
Add me to the testing list MI ID 6246326556.
With FW v2.0.6_0065 I’m experiencing the same problem with FW v2.0.6_0051. Can’t use in Domoticz, goes offline all the time. With FW v2.0.6_0054 everything was OK.
Could I please get added to beta group?
