Since the bulb has very large volume in market, the “grey” stage will be a bit longer than other models. Please stay tuned.
Please add me to whitelist
GERMANY server
GERMANY server
Thank you very much.
I have been updated today to version 2.0.6_0065 but it still fails, it disconnects from HA every 2x3.
The Android APP was also updated to 3.2.31 and this new APP fails much more, now it goes offline alone or says it is off when it is on.
Mi ID: 1763341038
Server: China
I think you have a problem with your W-Lan - since i activated the Internet to the bulbs and lamps again (i have 3 bulbs, 4 led stripes and 4 ceiling lamps and 2 bedside lamps) and i have no problems in Home Assistant (never disconnected since a lot weeks)!
This morning the 2.0.6_0065 firmware was available for me. Just updated my bulbs and seems to work in HA again
For me it is still “unavailabe” in HA with 0065…
Due I have a fresh installation of HA, i have to ask, how did you use your lamps?
I have at least configured the lamps like this:
(yeelight.yaml)
devices:
192.168.1.25:
model: color2
I am using this way https://www.home-assistant.io/integrations/yeelight/#example-configuration-manual
Did you enable LAN modus in the Yeelight app?
thanks for reply,
yes, the same procedure I have used here.
HA still show me the ligths only as a homekit device, I could configure.(As far as i know is this the “bug” in HA that has to be solved?)
I am having the same issue, can I be whitelisted?
MI ID: 1750738312
Server: Mainland China
My yeelights are currently on 1.4.2__0076, which seems quite old.
@teprrr Any update about the discovery issue?
That needs to be fixed by the HA devs.
Yes I know, and teprrr is one of them
It’s the same with me, I have the latest version of HA and Firmware 2.0.6_0065 and it doesn’t work for me
Please add me as well
Mi ID: 1883510111
Server GERMANY
Hi please add me to all beta whitelists
Mi ID 1650151352
Server Germany
Mi ID 1555527066
Server Singapure
Same Problem with nearly every Yeelight Product
I dont understand why they dont release an update for every Yeelight product…
Please add me as well, I’m using HA
Mi ID: 6253076041
Germany
