There are disconnections after about 24 hours, but they always been. I’m not using Home Assistant, I’ve written my own firmware for esp8266, that controls bulbs and connects them to MQTT.
In case of disconnect, esp8266 reconnects to bulb at once, and it doesn’t bother me.
Without homebridge-yeelight plugin, bulbs always respond by TCP telnet connection to port 55443 (max 4 simultaneous connections, don’t forget).
So, guys, if your bulb doesn’t respond by telnet, first try to shutdown all controlling software and hardware at your network, Smart Home soft, etc. Maybe this software doing something wrong with your bulbs.
Still the same thing here on 0055 as well. Not being able to use my lights normally is getting really frustrating. They stay unavailable until a powercycle which is exactly the same behavior as before.
Yes, very frustrating. In my case all bulbs are manipulated via automation in HA. I don’t use the Yeelight app and my bulbs are all practically useless at the moment. This issue has literally affected and greatly inconvenienced people’s lives.
Some positive news then: upgraded my 8 bulbs (v2, color) to the 0055 firmware and have not experienced any disconnections since. Home Assistant works like a charm again. Thanks Yeelight devs!
If it helps anyone, all my bulbs have static IP’s set in the router and are configured in configuration.yaml as follows:
yeelight:
devices:
192.168.178.27:
model: color2
use_music_mode: False
save_on_change: True
I was happy like you, until all bulbs disconnected altogether after 2 days.
Hi, could you please add me to the beta group? Can’t see any updates. lights randomly become offline in both Google Home and Yeelight app. Singapore server, mi id 6245070457
I’ll move myself over to this topic (previous topic fw 51 from 38) I, too, need a fix for these issues.
Mid 1880846078
:wave: Hello,
Is there any release date for this issue ? Otherwise please had me to the beta version :innocent:.
Mid: 1815633601
Thanks :pray:
The bulb connection issue is over a month since firmware upgrade to 0051. Then no solution after 0054, 0055 … Many other user already post threads about the issue of disconnection of the 0051, but still, no solution at all.
I do believe that people in this thread do use home assistant. It’s meaningless that other software, yeelight app or custom firmware etc can control the bulb. It’s above home assistant. And many people, like me, buy yeelight bulb because it work with home assistant. But since 0051, it won’t work anymore. Should I throw all my bulb away and buy other brands?
At first, this post request to downgrade the firmware. But yeelight staff reject it and said this will ‘harm’ the bulb. I’m not an expert, but I do flash firmware of many different devices many time. I already know that It is a risk of flashing firmware. If I can take the risk of bricking my bulb. (for me, the bulb already is a brick and useless) Can yeelight staff provide firmware downgrade for me??
Thank you for adding me to the whitelist Id 1845644249 // German server
Same problem as everyone, my 24 yeelight works with Jeedom but the local connection is lost and impossible to control the lamps since the update
The ideal would be to be able to return to the old version …I am stuck to use the 24 bulbs of the house…
cordially
we are working on this issue as 1st priority now but it’s impossible to reproduce this problem in our lab. we are pushing the chip vendor to check their firmware too, so please have some patience.
Exactly my situation. Bulbs are considered bricked anyway (if you think about it, it’s the upgrade that actually bricked them). No risk at all flashing old firmware. Nothing to lose. f downgrade is not permitted and no working solution is offered, lots of people’s money are wasted.
Still going strong here after 60 hours, so I’m hoping for the best then :slight_smile:
Please add me to beta also - id: 1869273295
Same problem here with firmware: 2.0.6_0051
Please add me to beta also.
I realised same thing to mi gateway. So those who haven’t upgraded their firmware please refrain to do so.
I’m looking a way to quit from xiao mi if they can’t solve it in another mth time.
Please add me to the beta ID: 1860329985
So, here comes 2.0.6_0056… in the hope of being stronger than v55. If v55 is good enough for you, pls hold on for a while.
Can you add me on the beta
Id 1845644249 German server
Thank you
I have the same problem.
When i change the color or the brightness by home assistant, sometimes the light becomes unavailable for about 1 minute.
Can you add me on the beta ?
My ID is : 6250593180
