吸顶灯总是断线,重新初始化就可以连接,随后还是断线无法自动连接 每次开灯都是断线
能帮添加白名单吗 ID 310990441 谢谢
用的哪款灯?
账号1008206232,米家LED吸顶灯,固件版本2.0.2_0026。经常离线,离线之后如果用小爱同学唤醒,会提示:哎呀,吸顶灯不在线,请检查一下网络吧。
路由器挂载了多少设备?先尝试下修改路由器的dns试试,把dns改为223.5.5.5
一直用的是小米路由器,路由器下设备14个,飞利浦的灯、yeelight彩光灯使用好几年都一切正常,就这个吸顶灯经常离线,离线之后蓝牙网关好像也有问题,导致靠蓝牙联动的场景失效,必须重启电源。应该和路由器没关系,请问有其他办法吗?
Please look on the discussion above. It seems that it is firmware feature of the lamps. Once in several hours it drops IP address and tries to receive it from DHCP. In most cases successfully, but sometimes - not. And in such a case lamp goes offline.
I have 5 lamps and from the log I see that they drop connection (goes offline and back online) simultaneously multiple times a day.
小米账号:24542627 Yeelight 皎月LED吸顶灯 固件版本掉线了看不到,最近经常间歇性掉线,请添加白名单
米家LED吸頂燈常掉線
嘗試設定固定IP,更換路由器,DNS
仍然發生(必須斷電再開)
小米ID: 1586274390
吸頂燈數量:6
固件版本: 2.0.2_0192
請協助設定白名單,謝謝
Same problem with my ceiling lights. They go offline and need a power reset to take them live again.
我的吸頂燈無法正確添加到APP
救命~~~
MI ID:6317640905
小米账号414674910,一样掉线,救命
有没有解决离线的这个问题啊,经常性的离线
Yeelight 皎月LED吸顶灯 480
固件:2.0.2_0048
不能用米家控制
小米ID 3613253
米家客厅吸顶灯
固件2.0.6-0025
无法升级至2.0.6-0029
米家卧室吸顶灯 450
固件2.0.6-0025
无法升级至2.0.6-0028
米家吸顶灯套装(客厅灯、卧室吸顶灯450、卧室吸顶灯350,丢包严重,反应迟钝或时长掉线)
路由器:Redmin AC2100 路由器
小米ID:2304327632
请添加白名单,谢谢
固件2.0.2_0192,小米id 6171520439
I have the same problem. It provides Wi-Fi connection, it only helps to unplug the cord from the outlet and insert it, but this also works for 2 hours. In the settings of the router, I see how the lamp tries to reach the router for 4 seconds and turns off and does so endlessly.
@dingyichen why this issue is still not solved after more than a year? The smart functionality is worthless if the ceiling light constantly goes offline. I bought a very expensive simple stupid ceiling light.
@_guofeng any news on this issue?
What’s the model of your device? Please view it at the Device Information feature.
Model: yeelink.light.ceiling3
