小米ID:6316827759
Yeelight皎月 650mm LED星空
固件:1.5.9_0053
请添加白名单
小米ID:1845352038
Yeelight 皓石 LED 吸頂燈 PRO
固件:1.5.9_0021
请添加白名单
小米ID:1845352038
Yeelight 皎月 480mm LED星空
固件:2.0.2_0048
请添加白名单
小米ID:1845352038
Yeelight 皎月 650mm LED星空
固件:2.0.2_0056
请添加白名单
官方好像没有要解决这个致命的问题。也是因为这样把物理开关又加上。真想说脏话
小米ID: 377769951
米家led吸頂
固件:2.0.2_0025
请添加白名单
升級固件以後app反應很慢,且常掉線。
几个月都无法修复该问题
Please add me to the whitelist too:
Xiaomi ID: 1595692303
450mm White Firmware: 2.0.2_0048
480mm Starry Sky Firmware: 2.0.2_0048
450mm Starry Sky Firmware: 2.0.2_0048
650mm White Firmware: 2.0.2_0056
小米账号 1045133828
纤玉客厅灯
固件 2.06 0038
掉包严重 控制延迟 无法升级新固件
刚买不久,米家APP一直显示离线,完全无法联动家里的其他设备。不管是哪款,只要是yeelight的都显示离线。希望加白名单会好一点:ID 2332757977
米家ID:1835414957
麻煩白名單一下
As I have 5 Ceiling Lights and I started monitoring of their activity. 4 of them connected to one wifi router and one to another. I found very interesting thing. It seems that disconnection from wifi is not a bug, but a feature of the devices as I see from the log, that they dropping connections with wifi at the exact same time, even been connected to different routers. Also other devices in the network (IoT, laptops, cellphones, etc) does not have same issues at that moment.
Positive observation is that in most cases ceiling light reconnects to wifi less then in a minute, but some times failed.
Today log:
2020.06.23 4:46:06 YLXD02YL, Light state: unavaliable
2020.06.23 4:46:06 YLXD17YL, Light state: unavaliable
2020.06.23 6:10:24 YLXD16YL_mish, Light state: unavaliable
2020.06.23 6:20:39 YLXD17YL, Light state: unavaliable
2020.06.23 6:52:10 YLXD05YL, Light state: unavaliable
2020.06.23 6:52:10 YLXD17YL, Light state: unavaliable
2020.06.23 7:03:32 YLXD16YL_andr, Light state: unavaliable
2020.06.23 7:23:41 YLXD05YL, Light state: unavaliable
2020.06.23 7:35:03 YLXD16YL_andr, Light state: unavaliable
2020.06.23 7:35:03 YLXD05YL, Light state: unavaliable
2020.06.23 7:35:03 YLXD16YL_mish, Light state: unavaliable
2020.06.23 7:35:03 YLXD02YL, Light state: unavaliable
2020.06.23 7:35:03 YLXD17YL, Light state: unavaliable
2020.06.23 7:55:12 YLXD16YL_mish, Light state: unavaliable
2020.06.23 8:08:36 YLXD16YL_andr, Light state: unavaliable
2020.06.23 8:08:36 YLXD05YL, Light state: unavaliable
2020.06.23 8:08:36 YLXD17YL, Light state: unavaliable
2020.06.23 8:16:57 YLXD02YL, Light state: unavaliable
2020.06.23 8:28:45 YLXD16YL_mish, Light state: unavaliable
2020.06.23 9:00:16 YLXD16YL_mish, Light state: unavaliable
2020.06.23 9:15:46 YLXD16YL_mish, Light state: unavaliable
2020.06.23 9:43:09 YLXD16YL_andr, Light state: unavaliable
2020.06.23 9:43:09 YLXD05YL, Light state: unavaliable
Model numbers of my lights:
450-YLXD16YL
450-YLXD16YL
480-YLXD17YL
480-YLXD05YL
650-YLXD02YL
haha
It means they are ignoring DHCP refresh timeouts and that during the IP reissue, they lose connectivity. I have seen it with my devices. When blocked Internet access (I am using home-assistant, so LAN mode is more than enough), Yeelight ceiling lights performed this operation every five (5!) minutes. Try this and you will see that they ignore your DHCP timeouts. It’s just that. Ever since firmware 2.x
同样的问题,WIFI疯狂掉线。
小米ID:10561868,Yeelight 韶华LED吸顶灯,固件版本:2.0.6_0008
@timq0748 @sihan007 @dingyichen
哪位大佬抽空救救可怜的娃。感谢~
我用的是360路由器,Yeelight 韶华LED吸顶灯 的连接状态并不是一直掉线,是间歇性离线,发出的指令要么不响应,要到隔了半分钟才有反应。
而和它同一组的台灯是立即响应的。对比非常明显。
@ezaton @zsqduke @liufei
哪位大佬抽空救救可怜的娃。感谢~
我的已经几个月的了,厂家好想是修复不了
改信道,wpa2试试
Good observation.Do you manage to assign static IP addresses or disable this refresh time?
I did not try to set fixed IP from Yeelight interface. I have reserved DHCP addresses for these devices. Also - changed DHCP renew times, but for no avail. Five minutes, and about 10-30 seconds of timeout during the refresh (actually - exactly after it) every time.
Me too. But I decided in other way. I installed smart switches, which allows me to use different click types to manage the light. And my Home Assistant monitors status of the Yeelight lamps. In case they do not appear online in 2 minutes it just physically do power off/ power on. And connection restored
However I need to mention that in 90% on cases re-connection happens automatically.
But fixing this issue can help.
