Cannot add ceiling light to yeelight app
When I am trying to add a new device to my yeelight account, I am unable to add it. During the process, it fails after reaching 100% stating connection timeout.
The app offered me to connect manually to the light. After failure during first addition (even tried resetting), the yeelight SSID cannot be found. As such I need to reset the device everytime I want to add the device.
After reset, i can find the yeelight SSID. Please see screenshot below.
Please help me to add my ceiling light to my yeelight account.
Thanks,
Neelesh
Could you setup a hotspots with another phone and try connecting the bulb to it to see if it works? If yes, you can try change DNS of your router to 8.8.8.8 and then connect again.
And BTW,what’s your xiaomi account?
I will try to the hotspot method later during the day.
My account id is 6162487416.
Seems you are the case, please refer to the topic:
Should I use recommended server? In my case, it is Germany.
Yes, you can have a try to see if there’s new firmware update.
The above method worked. Thanks.
