Problem installing the WiFi bedside lamp !! Help me !
#1
Hello, I just bought the Yeelight bedside lamp (Gold WiFi version).
I downloaded the MI Home application and I want to add the lamp.
I’m booting up my wifi connection on an access point password with just simple characters.
I find the lamp and trigger the connection.
At 100% I get a message
expired request
however from the access point, I found that the lamp (yeelink-light-bslamp1_mibt88477608) got its IP address. That during the connection sequence the lamp tried to connect to the following server: <de.ot.io.mi.com>.
query [A] from.ot.io.mi.com from 10.3.141.181
forwarded from.ot.io.mi.com to 8.8.8.8
reply from.ot.io.mi.com is 52.57.237.31
reply from.ot.io.mi.com is 18.194.20.12
reply from.ot.io.mi.com is 18.194.138.155
Several packages are exchanged before arriving at
I also found that the lamp emitted broadcast messages
Host: 239.255.255.250:1982
Cache-Control: max-age = 3600
NTS: ssdp: alive
Server: POSIX, UPnP / 1.0 YGLC / 1
I saw a reference to http://android-dev.yeelight.com/factory.apk
impossible to use
Can you help me please?
#2
How about changing DNS of your router to 8.8.8.8 and try again?
#3
this is already the case and we can see it in the trace
#4
Please check if you are the case:
