Hello everyone,
I have just recieved and installed 3 color LED bulbs and I love them so far.
I have tried some things with IFTTT and that’s great as well. What I did not manage to do: On a trigger, say a stream I follow goes live on twitch.tv, I want the bulbs to flash purple 3 times and then go back to the color they previously had on. If they were off, they should turn off again.
Is that possible as of now? In IFTTT I can make them turn to a scene but then they are going to stay in that scene without going back. No flashing possible.
If anybody could give me some information here, I’d really appreciate it.
Thank you! I will be patient. Notification like triggers will make this the best bulb there is. Also, the quick support in here has been impressive. Who needs Phi***ps anyway.
Hello, where would I find that ?
I’m using the iOS app - could it be that it takes a while to get the update there ? Because there is none as of now.
Thanks !
Do we have any control over the amount of flashes, the intestity, the colour etc? Also the scene doesnt go back after the flash is over…
Can you send those options to IFTTTT please
Yes, can we change the settings off this scene, or add a new mode like flow? At the moment I dont really see much use in this because I cant go back to the current state it was before.
That scene is configured to restore previous state once complete. But we found there is a bug, that it could only work when the bulb is open before this scene applied. Which means, if it was closed, the bulb will keep open; if it was open, the bulb will restore to previous color/brightness once the scene complete.
But anyway, Could we get an IFTTT Action of “Blink Lights, turn lights on and off” “Flash: Flash your light with this color temperature and return to previous state”
I think i’ve found another bug. I Goto favourite -> Romane (Or any flow scene) -> Flicker (At this point it returns to the state before romance) -> I exit out of Favorite menu and then press Flow on the bottom, and I get the flicker effect again.
