Hello!
I am interested in ordering a yeelight bulb, I was wondering if it is possible to connect it to an entreprise wifi, with a username@domain and password. Eduroam for example.
Thank you!
Hello!
Thank you!
I do not quite understand what is entreprise wifi. Currently it doesn’t support wifi access points (or the portals which serve as “sign in” pages for visitors and guests) and I think it is OK for others.
Here’s what I found on an Apple thread : “WPA2 Personal is the main WiFi security method and this is what most home and small business users use. It uses a single password. Most WiFi networks use this method. WPA2 Enterprise is also called 802.1x and is the enterprise method. This method shouldn’t be used by home users as it requires a RADIUS authentication server and needs a username and password. It supports multiple accounts for each user.”
Basically you’ll have to put the ID+pw within the wifi settings when you’re on your phone or pc (with classic wifi there’s only a pw).
I found this image on google :
Actually Eduroam uses 802.1x EAP, it connects the same way in practice.
The bulb can only work with a router using WPA/WPA2 encryption method with a password, I think it’s ok in your case.
I just found this post : Wifi connection problem
Doesn’t look like it will
Is there any way you could support that?
Many applications for social media accounts are really useful when it comes to promotion. I really like how https://zen-promo.com/instagram_ghosts_cleaning works when I use it. It’s another reason for me to make startup projects as they are always accepted by the auditory.
