I just buy my first YEELIGHT Strip and can’t add to app.
I reset the strip, i change wifi…app on IOS show 0%
Led from unit is flickering yellow
In my account i have another 8 bulbs RGB on server china and work great.
What to do? Thank you
1)Reset the lamp by power on and off fives times 5 times in a row, and then see if there’s AP named like “yeelink-light-***” in your phone’s wifi list? If yes, go to see Step 2; If no, it means there’s something wrong with the wifi module of your lamp;
I add device via android app to my cloud, then was transfered to iphone.
Seems to be a problem whit iphone app.
Now works
