Today my Mijia Desk Lamp stopped responding to google home command. Been trying to reconnect to google home many times but still doesn’t work.
Server: Singapore
App: Mi Home because I cannot connect the lamp via Yeelight app
I have the same issue since the beginning. Also in Singapore, I never managed to connect it to Google home. Same fact, after linking yeelight actions in Google assistant nothing appears in the list
Hi! Thank you. Let me try this evening when I go back home. But I’m 100% sure there is not WiFi ap yeelight in my environment. So something is wrong with the lamp. Turn on and off five times should do the trick,| no scene button pressed?
I am also having trouble connecting to my Desk Lamp using my Google Home. A couple days ago it stopped working with the Yeelight Actions service so I switched to the Mi Home service to control it. It worked for a couple days and now today both Yeelight Actions and Mi Home are unable to connect to the lamp.
I’m also having this issue: “account is now linked” message when adding Yeelight service, but next screen is not showing anything about Yeelight or Yeelight service either. Yeelight service looks like it didn’t really complete the Linking Process.
I have TP-Link and Philips Hue services linked in Google Home with no issues.
What can I do?
Thanks in advance.
PS: yeelight light and bulb is working as expected and I can control it from the Yeelight app. Also the same process with Amazon Alexa work es perfectly. My only issue is with Google Home when adding Yeelight to it.
I’m having the same problem. I’m not ablo to connect google home with yeelight or Mi Home. I’m conected to China server because is the only one that allow me to see my Yeelight Bulbs on both apps.
