same problem I read along the web.
I´m using an iPhone 8 Plus with iOs 11.3.1 and my app only reach 25%, so I cannot use my light strip.
What can I do?
What can I do?
1)Reset the lamp by power on and off fives times 5 times in a row, and then see if there’s AP named like “yeelink-light-***” in your phone’s wifi list? If yes, go to see Step 2; If no, it means there’s something wrong with the wifi module of your lamp;
Hi luhaobo,
Nothing happens, its still stucked at 25%, so I cannot use the app to show more colors in my light strip.
luhaobo, I tried connecting to the Singapore server and it works!
