Hello, I recently bought a yeelight but I can’t connect it. I was able to connect it once but the bulb was disconnected immediately.
I followed the instructions on Yeelight app but the connection failed at 25% or there is directly a message “connection failed, verify your information”.
I’ve reset the bulb many times and tried again, but it doesn’t work. I am using the Yeelight app on iPhone with the latest iOS version.
I have a 2.4ghz wifi network and I disabled the 5ghz wifi network. I tested on all servers in the app, but nothing work although the ping test is OK on all servers (sg.ot.io.mi.com、ot.io.mi.com、us.ot.io.mi.com, de.ot.io.mi.com)
I turn ON my hotspot to connect on it but same result.
I don’t know what to do.
Which bulb do you have, Version I or Version II? What voltage do you use, does it match the bulb?
Hello, I have the smart LED bulb (Color) V2 (YLDP06YL).
The voltage used is the french standard, 230v at 50hz, I think it’s OK because of the bulb lights up normally.
I followed the steps listed but nothing worked. I made many reset of the bulb but initialy I didn’t have problems with the AP in my phone’s wifi list.
The problems is from the step 2 where Yeelight app can’t connect the lamp when I choose them in the wifi list. My wifi password has no special character (only upper case letters & numbers) and there is no special character for password configured in Yeelight.
When I launch the connection, it’s still stuck at 25%. While charging at 25%, the bulb appears in DHCP list with no IP dedicated and it disappears when the message “Connection Failed” appears.
I made test with another phone connected on my router and same settings but I have the same result.
I made cross tests with 2 phones setup as 4G network hotspots but the bulb doesn’t connect.
All the test I made failed.
I got no idea about the issue, it seems there’s some network issue when the bulb try to connect to the cloud.
Which country do you live?
I’m from France. I tested on all servers and the connection failed but when I made a ping test on each server, all the tests succeded. It seems there is no domain blocking of my ISP…
Any solutions ?
i have the same problem from France too !!
Provider : Freebox and you ?
tried 4G Hotspot on B&you.
