I just received my YeeLight and I am trying to connect it to my wifi and phone.
My phone is LG G4 running Android 6.0
I tried connecting with both MiHome app and Yeelight app, on both I am getting the connection timed out message.
I’ve followed the instructions and searched the net for common issues such as these: https://www.gearbest.com/blog/how-to/fix-xiaomi-yeelight-rgbw-e27-bulb-app-connection-problem-1560
I’ve verified that my WiFi settings are ok, I tried resetting the bulb (5 times on and off) but I am still getting that “connection timed out” message every time.
I’m having the same problem with my lights. I had them working when I got them. the problem started when I need to add a new one, theregore I believe it might be the firmware since i try to connect on the newer firmwareI at this point…no luck they keep saying ‘timed out’ after 100% sometimes 50%. In any case they won’t show up in DHCP
I have reset the bulbs (they are recognized)
Used different Android devices
Reset my modem
Use DNS
I have a unbranded connectbox which is a use by Ziggo ISP its limited with settings… phone is a Huawei mate 20 Pro ( 9.0) I used my OnePlus 3T (8.0) too.
Tried to login to 2410552805, yeelink1234. BUT failed because someone changed the password…
Tried to change region to Mainland China and still no success(Used to be on recommended Asia and Oceania).
Tried to create new account this time chose Russia as region and still no success. It never asked me to update my firmware which is weird
What now and how can I fix the problem?
Thanks in advance!
I have the same trouble. My yeeligjt colour bulbs version 1 connection time out is coming after setting up 100%
After resetting (turning on and off 5 times), the bulbs behaves as expected - colour changes and then stabilise on white light. At this point, yeelight app identifies it as an incoming new device. When connected ato home 2.4 Ghz wifi connection, the hotspot created by the bulb connects to the phone and it says - connection successful. The connection status goes beyond 50% and message s says - updating connection status, pls wait. After this the status moves slowly to 100% and connection time out comes.
I don’t believe its a router DNS issue because other colour bulbs (but version 2), are successfully clobbered and working fine. My phone is Samsung note 20 ultra , but I also used note 10 with same result. Anyway changed dns on the phone to 8.8.8.8 but same result. Server is Singapore but changed to mainland China with same result. I bought 2 bulbs with same problem happeningmy wifi wonder is Nokia mesh becon. Yeelight people read this forum? Can anyone help?
I was having the same problem with all of the comments here, after resetting the light would stop at 50% and slowly count to 100 but not connected.
What i did to fix the problem step by step:
search on phone settings: private DNS
On the hostname: type the following: (dns.google) then SAVE
RESET phone, and RESET the bulb (i know youve reset it for like 1000x but do it 1 more time)
Remove the bulb and put it back
One of the two or the mix of those got my bulb fixed. After doing the steps above, i cleared my phone from all the apps running, oppened yee app and see that it finally works after hours of trouble shooting. One of the things above have fixed the problem.
What worked for me was making sure the SSID/network was set to 2.4 GHz, and most importantly, the security mode was set to WPA2 only. Don’t leave it on Auto or WPA2/WPA3 mixed mode.
Trust me, everything else will fall into place once you do the regular bulb reset and reconnect it. I tried all the other methods mentioned in this thread, such as changing the server, setting the DNS to 8.8.8.8, and more, but none of them worked for me.
As soon as I switched the network to 2.4 GHz and set the security to WPA2 only, the bulb connected right away!
