Could you try to use another phone as a hotspot, and then connect the bulb to your mobile network. If it can be connected successfully, it means there should be something with the network or the route.
If the bulb has connected to the router successfully and you can access our cloud, the I can’t tell why you are not able to see it in your device list.
Maybe try another phone?? You can also post some screen shot here, so we can take a look.
I can see it in the device list in your app. Then I touch it and the connection assistant starts. Reaching 100% it gives me the error: connection timeout. But I can see it in my DHCP-list on the router (as an offline device of course).
I already tried it with another smartphone in my LAN, didn’t work.
And I already tried it in another house, with another WLAN - there it is working without any problem, with MY phone. So it has to be an issue with my router configuration.
I am having a similar issue.
I was able to successfully connect the lights the first time. I had to change my wifi settings, and after that i cant seem to connect it anymore. Trying since 2 hours but not successful. Can you please help?
I`m having the same problem, but I use two routers… the second one, which is in my room I just disabled the DHCP… so should I need to include the IP of the bulb and the mac adress in the adress reservation option? What is happening? and how can I find the IP and the MAC adress of the bulb?
