Yeelight Bedside I is a bluetooth based device while MIjia Bedside Lamp II is a wifi based one, so they are different in some features. “Sunrise” will gradually increase intensity from the schedule time, not until the programed time. So with Schedule in Lamp II , you can also do the same thing with Lamp I. For example, if you want to wake up at 6:00 AM, you can schedule a Sunrise light at 5:45AM, the light with gradually increase intensity in 15mins.
a) is there a possibility to connect the google alarm clock in the phone somehow to the yeelight app? so that you can setup the alarm on your phone and the app will start the sunrise accordingly?
b) my bedside lamp will not reset. tried it already many times, since I wanted to connect it to the MiHome App due to act as the bluetooth gateway for the xiaomi temperature meter.
-> press and hold button and plug in power supply. or is there a different way to do it?!
Xiaomi Mijia Bedside Lamp looses connection, when router reboots. All other devices in MiHome reconnects automatically, but the lamp needs the plug to be removed and inserted again.
Could you, please, publish the newer version of firmware to fix this bug?
I have tried this case in firmware version 1.5.5_0164, and my Mijia Bedside Lamp can reconnect automatically. Please check the firmware version of your device, if the version is not newest, update it and try again.
