Updated Firmware and now the bulb wont reset
Hi There,
I have 5 no. LED Bulbs (colour) and updated the firmware to them, 4 off the bulbs updated with no problem and reconnected as before.
But 1 no. bulb seems to have updated but now wont connect or reset. I go through the process of resetting by turning on and off 5 times till it flashes colours, then connects to the bulb through the App by wifi, then in the app it gets to 25% and then fails, with a X in the circle.
I assume that the firmware update didn’t work, so is there any other way to reset or updated the firmware.
Regards
Bruce
I have the same problem. Has anyone found a solution?
@MrSean
Sorry for the issue, please let us know which step do you stuck?
My bulb was working, but as I did the firmware update, it started to flash and change colors.
4 white, then all the colors. This sequence repeats continuously. The app said update did not complete or was interrupted.
The bulb showed as not connected in my MiHome app.
I tried to turn it off (since it was still flashing). When I turned it back on, it kept flashing again.
I tried to reset it by turning on and off 5 times, but it just keeps repeating that flashing sequence and does not stop.
I posted yesterday and received a reply within 3 minutes. I replied to the follow up and still have not received a response 24 hours later. The original poster waitied 4 months and did not get an answer. Am I wasting my time or should I just return my items?
Sorry for the issue.
Please contact your retailer for a replacement or refund.
