Stopping a transition after it has begun
In order to dim the light using a zigbee button switch (which can register both when you press down the button and also when you release it) I need to be able to stop the dimming command after it has begun and have the light not reset the light to the properties it had before the transition.
When I use the stop color flow function it just sets the light to whatever properties it was from the beginning.
What I want is something like:
In pseudo code:
if brightness == 1:
    if button_down:
       start_dimming(to_full_brightness)
if button_up:
  stop dimming()
  if brighness < 100:
      print( 'Brightness is now more then when it started but not full brightness' )
Is this possible somehow?
