Hello, I just bought Yeelight Bedside Lamp (Gold WiFi version). When I download the MI Home app or the Yeelight app and when I want to add the lamp, it says to reset it. I do it exactly as it should be (hold both buttons until the light starts flashing colors) but then it can’t find the lamp.
If I recall correctly, I should be able to see the lamp in the list of WiFi, but I can’t see it there.
Can you please help me, is it bad lamp and should I return it, or is it some other problem?
Hello. Yes, I tried not second phone, but tablet Xiaomi MiPad. Still no WiFi named yeelink. Only some Bluetooth device (i dont remember the name, but I found on the fórum that it should be for voice control).
I can send you S/N when I come home from work. Yes, I’m resetting correctly (Hold both buttons until the lamp starts flashing and then returns to default light).
I suspect that the lamp is in factory mode, so could you follow the steps below to make sure if it is:
1、Setup a hotspot with your phone, name: miio_default, password: 0x82562647, encryption method: WPA2 PSK.
2、Check if the lamp connected to miio_default automatically. If yes, the lamp is in factory mode, otherwise not.
I tried to restart the phone, set up the hotspot again, the lamp connected, then launched the factory.apk, but still when I try to press FIX, I get the error message to set up the hotspot manually.
I really hope you can help me fix it so that I don’t have to return it…
