thank you very much, after two years if finally works
I am able to login with this account and setup my Philips/Xiaomi E27 but it tells me that the firmware is up to date, no firmware updated available. Is there a trick to update the firmware?
And of course when I go back to my own account I am not able to setup the bulb.
6175061422 does it need to be white listed?
What’s the model of your lights?
Hello
I have three models:
1- XIAOMI MIJIA Philips E27 Smart WiFi LED Ball Lamp
https://www.tvc-mall.com/details/xiaomi-philips-e27-smart-wifi-led-ball-lamp-sku89010674a.html
2- Smart Bulb Xiaomi Philips smart E14 LED candle bulb matte version (9290018615)
3- PHILIPS 9290012799 200lm 3000 - 5700k Adjustable Color Temperature Downlight ( Xiaomi Ecosysterm Product )
Many thanks for your help
It’s not our product and Yeelight app not support it.
Actually they work perfectly with the Yeelight App but not with the Mi Home App.
I was hoping you can help me make them work with the Mi App
Update,solved:
I’ve solved the problem. It was a 5 GHz vs. 2,4 GHz Issue.
Solutions:
a. Turn of 5GHz off temporarily. After connection has been established re-enable.
b. Set up a temporary 2.4 Ghz Wifi with identical SSID and PW-
Hi there,
I already have a working mi bedside lamp (newer model with golden base).
I bought another one from a friend who never updated it.
The lamp is discovered in the yeelight app but connection times out.
What are the steps to update the firmware?
I am able to login to the app with Account: 241… as described above,
but I am getting the same timeout problems.
The login is not working anymore. is there another one i can use?
This account should be cancelled. Really Annoying. I will think of a way.
Bro help me… Login failed… Give me another account
Someone change the password… Please help me
What is the correct username and password so I can login and hopefully update my firmware?
@dingyichen please reset the password, someone change the password …
I’m also stuck in the same situation, please provide an account for us to be able to use your guys products properly.
Nati.
Hello
I have connection timeout pairing LED Ceiling Light Crystal Plus with mihome account 4179727052
Maybe you can add me to whitelist?
Please add me to whitelist
Id 6481731351
Regards
Hi dingyichen,
I hope you might help me…
I do have 3 pieces of Yeelight Ceiling lights that I purchased in 2017/2018 and never installed — until I now have the placr to do this.
I keep getting “connection timeout” all the time and I do see that my Ceiling light has received a IP-adress and I can even ping it, but it is never discovered in the Yeelight app.
My xiaomi acccount is bigger than 4294967295 (32bit), so I wanted to try to update the firmware, but the account: dingyichen@yeelink.net , Password: yeelink1234 does not exist anymore – password changed?
Please get me some support on this issue.
Big thanks in advance.
Rudi
I have the same timeout connection error with a Mi Bulb White and color. My account is bigger than 4294967295 (32bit), can you give me the correct ID to try to update the firmware? My ID is: 6483669959.
Thanks in advance,
Giuseppe
Seems that I would need to be put on a whitelist to be able to do this?
My id is: 6423190288
And what logon account + password would I then need to use to login and upgrade firmware?
rgds Rudi
My account is: 6423190288
I’ve tried to login with xilin@yeelink.net without success…
Please support…
rgds Rudi
