I got my Yeelight Bulb (color) 220V from gearbest before 2 days, And just can not connect to router / hotspot
not from yeelight app and not from mi home
yeelight - until 99% and then ‘timeout’
mi home - connect - send message to the device - and fail on last step
I checked the last two days of every article I found, in google and in the forum
The device is identified in DHCP, and in all the devices
- Switched all the servers, china, us, singapore, russia, german,
- Reset the bulb many times… again and again…
- Installed a 4G access point from another device
- Tried to get close to bulb and to connect to different places in the house
- Wifi 2.4, i also created new ssid, password only numbers: 12345678 or 12341234
Google dns: 8.8.8.8 / 8.8.4.4 - Tried to set up a local dns server with simpledns, but i do not have a router option to enter domain only ip so i did not know what to type
- Open port 8053 UDP and 80 TCP in the router
Router is from my ISP:
ZXHN H198A
Country: IL - Israel
Nothing help, I’m not sure if it’s a bulb problem or just network problem,
or just i miss something
MI ID 1885895475
Pinging ot.io.mi.com [120.92.96.242] with 32 bytes of data:
Reply from 120.92.96.242: bytes=32 time=236ms TTL=42
Reply from 120.92.96.242: bytes=32 time=239ms TTL=42
Request timed out.
Ping statistics for 120.92.96.242:
Packets: Sent = 4, Received = 3, Lost = 1 (25% loss),
Minimum = 236ms, Maximum = 239ms, Average = 237ms
(before 24 hours sg give me result, but my ip changed in the last 24 hours and now i receive this)
Pinging sg.ot.io.mi.com [47.88.222.245] with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 47.88.222.245:
Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
Reply from 120.92.96.242: bytes=32 time=237ms TTL=42
Minimum = 237ms, Maximum = 239ms, Average = 238ms
