Hi, i have 3 LED Bulb (color) 2, 1 i got it like 1-2 week(s) ago which i had set it up successfully to the yeelight app in my iphone after some trouble. I just bought 2 new bulbs and want to connect it to the app again. However, i can’t do it successfully. It always stuck at 25%, and then it failed. I have tried to reset the bulb couple times and use mi home. And it doesn’t solve anything. Any solution? I can’t find the mac address of the 2 new bulbs. My account number is 1880508733. I tried to setup the bulb around 9-10 pm gmt+7
And at last please use another phone to setup a hotspots with 4G network and try connect the bulb to it, I want to make sure if the bulb is ok.
Or could you have a try with changing your router’s DNS server to 8.8.8.8 instead of using automatically allocation?
Thanks,
Andy
