Bulb won’t reset
I have 5 color changing bulbs. I try to reset but it will flash and rotate colors or it will have me go through the reset steps over and over then back to constant flashing. They worked well for about a month now this. Please help!!!
What voltage do you use? Does it match with the bulb?
I’m having the same problem.
I’ve reseted the bulbs several times but i cant get them connected to the app.
They blink and then I start the connection… it goes to the 25% and crashes.
I have 5 bulbs and only one is still connected…
What can I do?
