10W bulb turns off and back on intermittently
It turns off or very low every so often. The higher the colour temperature is set the more often it happens, every five or ten minutes, and it may flash once or twice before coming back on. Reducing the colour temperature with the slider will bring it back on. Increase it and it will go off again.
Another identical lamp under the same conditions does not do this.
I have 3 color v2 bulbs, one of the bulbs i have also does that. I was thinking that maybe this happened because this bulb was often being switched on-off by using the wall switch but apparently other people were encountering this too. maybe some units has a defect or something ?
