my phone cant connect to mi desk lamp anymore
Hello.
I have been using the mi desk lamp for about 2 weeks now and it is working perfectly. I can use the mi Home app to change the temperature and the brightness and I can set schedules so it turns on every monring at 6 to wake me up to go to work.
But since yesterday the schedules dont work and and I cannot connect to it with my phone anymore. The lamp is perfectly functional manually but it is not a smart lamp anymore.
I tried reseting it by pressing the reset button at the bottom and I still cant connect to it.
Which device do you use, Wi-Fi based version or bluetooth?
Wifi version. I dont need to have bluetooth on to use it
You need to hold power button and scene button at the same time for about 5s to reset it.
You are the Best.
2 worked
Thank you very much
Good to know :wink:
